No i've only found the key swictch wich is front on my eyes but not the switch to turn off I can't see it on the handlebar. My first problem is the engine doesn't start so fuel is ok, spark plug is wet, and engine would run nearly but not. Sparks on spark plug are ok. Fuses are ok so I was searchin' for security switches maybe? I'm searchin for atv repair manual soon..
It should be on the left side of the handle bar  it’s red. It’s right above the start button.
 It may be missing or the red switch cover is gone? Can you post a pic of that left side of the controls on the handlebars ?
Should look like the pic attached.
Ok that makes sense now.  That’s not the correct switch for that machine.   I would order a new switch or a used one from eBay. An original equipment  manufacturer  switch (Yamaha). The wires should all be color coded and match what wires are on the harness.
I’m assuming someone put a cheaper switch on the bike because of the price of the right one.   I looked at a few switches on eBay and they run about $90 bucks.
If the bike is in good shape I would do it.
Ok thak you very much I will search for it. Now I will also search the 2 wires R/B and R/W back of the radiator to be sure that CDI unit is not at ground and engine doesn't run. Thank you my friend I'll tell you later about my problem 😉
Is the  disconnected  cable on the left  for  the  choke  or  is it the  rear  brake  cable that  should be connected  to  the  lever on the  grip?.  The right  lever  with the  hydraulic  cylinder should be your  front  brakes ,  at  least that's the  way their set up  on most machines .
Yes the left cable is for the choke but the system is broken so it doesn't hold now I have to pull up with my fingers if I would start engine, not really practice lol but I will repair it soon and the right lever is for front brake yes
    • By flyinbrian365
      Factory service manual
    • By flyinbrian365
    • By crankin
    • By Zrach
      I wanted to share a successful workaround for a "no-spark" issue on a 2009 LT-A400.
      This is specifically for cases where the CDI has been diagnosed as faulty, but the age or condition of the machine makes the cost of a brand-new OEM unit hard to justify.
      Note: This modification compromises the factory “no-start” circuits.
      On some malfunctioning CDI units the internally damaged circuitry is only partial.
      Feeding full time power to the Parking Brake pin, the unit is triggered to bypass the internal fault and produce a healthy consistent output to the Ignition coil.
      The Modification
      See the second diagram attached below for the wiring specifics.
      The Result:
      The machine has clocked over 1,000km since this repair and is still running strong with no ignition dropouts.
      ⚠️ IMPORTANT SAFETY WARNING ⚠️
      Please be aware that this modification compromises the factory safety "no-start" circuits.
      The machine will now start in gear. The safety interlock involving the handbrake is no longer functional. The machine can move unexpectedly if the starter is pressed while in gear. Proceed at your own risk. If you sell the machine or let others ride it, ensure they are fully aware that these factory safety buffers have been removed.
      Faulty CDI Workaround.pdf
    • By fwsamm
