2002 Yamaha big bear carb question
By HSTAR
By ResQ91
Hi guys
battery and connections good
By utvboard
2009 HONDA BIG RED
Big Red
KEY FEATURES
2009 Honda Big Red in Camo
By John Sinclair
I WANTED TO UPGRADE THE CARBURATOR ON MY 1992 BIG BEAR 350, SO I ORDERED A NEW CARB FROM EBAY. ACCORDING TO THE WRITE-UP IT WAS A GOOD FIT FOR BIG BEARS FROM 1988 TO 1996. WHEN I REMOVED MY ORIGINAL CARB I NOTICED THAT IT WAS DIFFERENT FROM THE NEW CARB MY CARB HAD TWO THROTTLE CABLES THE NEW CARB ONLY HAD ONE CABLE. HOW CAN I MAKE THIS CARB WORK ON MY TWO CABLE THROTTLE? -
By McG75
