From what I've read, the only function of a resistor is to prevent radio frequencies from interfering with automotives with onboard computer systems. If the only function of a resistor is to prevent damage to a vehicle's computer system, then why would they not be standard for every vehicle equipped with a computer? Are there downsides to using them?
I think you are referring to a ferrite bead choke
https://en.wikipedia.org/wiki/Ferrite_bead
A resistor does nothing to block EMI interference, it is designed to resist the flow of current. They are commonly used for LED lights to limit the current to the LED to prevent the LED from drawing too much current and burning out prematurely.
The use of EMI filters or chokes depends on the application. Some circuits or cables are very sensitive to interference. An example would be in automation systems (production machine) that uses PLC controls, the communication between the modules is low voltage and high frequency, so it would require these filters to prevent false signals.
In a vehicle, the process of generating the high voltage needed to fire the spark plugs would produce frequency interference so some components in the vehicle would be shielded to prevent signal interference as an example.
Mike
I  don't know  of any  downside to  using resistor  plugs .  They're not necessary on  older  non-electronic ignition  machines,  and  non-resistor plugs  are unlikely to  cause  problems on newer  ones. In my opinion it's always best to  go with the  plug types and  heat range recommended  by the  machines manufacturer.
    • By Eisenmatt17803
      Good Morning!
      Has anyone had a problem with the small aluminum 90 degree elbow popping out of the valve cover and blowing oil all over the place? It looks like it is simply pressed in and will most certainly repeat the offense. Any experience you all can share with this issue?
      Thanks in advance.
    • By Malta54
      I own a 2007 Polaris Sportsman EFI X2 model and have for the past months been experiencing loads of issues. Basically the Sportsman will only start if the throttle lever is pushed and will not remain on idle. This situation has persisted for months now and I have replaced the following parts:
      Sparking Plug
      Fuel Injector
      Fuel Pump
      Fuel Filter
      Fuel Valve
      Fuel lines
      Power Control Module
      The last part replaced was the Power Control Module and the Sportsman was tested and worked fine on a couple of occasions which were days apart so much so that some weeks later I took the Sportsman for an extensive ride and it worked perfectly. This was three weeks ago and today I tried to start the ATV it worked fine a few minutes and decided to switch it off so that I could continue with some prep work. A few minutes later tried to start it up again but noticed that it would only start if the throttle lever was pushed and once I removed my finger from the throttle lever the engine would not stay in idle and would simply shut down. Several attempts were made to start this and also tried to re-adjust the setting by turning the built in wheel like mechanism in the throttle cable but it was to no avail.
      The above have been repeating itself on an off basis. Each time a part is replaced the ATV would work and then all of a sudden will not keep its idle. At this stage I cannot think of any other solution other than possibly some sensors which might have an intermitting fault but I cannot really say.
      Would greatly appreciate any assistance.
      Thanks in advance.
      Are there any good mods for adding a radio, or Bluetooth speaker that's kid friendly? My son thinks he needs music while riding around.
    • By prdicon
      Hi
      Are you using any spray to prevent mud from sticking to the ATV.
      Both plastics, and engine.
    • By Hermi
      I have this ATV that was given to us by sister inlaw...and look like the fuel filter fell out when drive around....but i can find anything on that system. if anyone could be soo AWESOME to please post manual and/pr pick of where the fuel filer goes that would b GREAT!!!!
      Thank you all for any help!!!!!!!!
