2002 Kawasaki Prairie 400 4x4 Vibration
Similar Tagged Content
By oxidized_black
1997-2002 Kawasaki Prairie 400 Service Manual
View File 1997-2002 Kawasaki Prairie 400 Service Manual
By Chopermech
Check this out:
I have been working on these and trying to get the word out on the forums.
I am now at the point to be able to start doing struts for others. If you haven't kept up with my progress, I have developed adding external reservoirs. It would be an approximate $(contact me for current pricing as some things have gotten cheaper and some have not) cost for both struts which includes adding bungs and all parts, including a lower magnetic drain plug. It would be a complete assembly ready to install with minor tweaking once on the atv (such as line routing) but nothing significant
Send me an email if you have particular things you want done or suggestions based on problems you are encountering with the oem set up. I can help you decide which route to go.
Here in the following pic of my manual, is a list of OEM part number struts I have developed this program for. Basically, it will encompass all SRA's with a front strut like the one in the picture, even the ones with a slightly diferrent lower spring perch.
If you are interested in an affordable and better front suspension on your utility SRA, please email me at: [email protected] to ensure I get your correspondence, since my inbox on the forum periodically fills up.
http://www.kawieriders.com/forum/showthread.php?p=1314451#post1314451
By Sonders
It appears that the Service Manual thread at top of forum is dead as all the links no longer work. I'm actually looking for service manual for a 2000 KVF300 Prairie that I just picked up. Does anybody have link to one that they can share, or know where I can find one? Thanks in advance for any help.
By Spartacus Stroppel
View File 1999-2002 Kawasaki KVF300 Prairie Service Manual
1999-2002 Kawasaki KVF300 Prairie Service & Repair Manual
Submitter Spartacus Stroppel Submitted 08/25/2019 Category Kawasaki ATV
Similar Topics
By BuckBilly
By BuckBilly
By Sha35297
Hello, got this bike in to replace the jug and piston. Made the swap, crank looks good, no play in connecting rod. Put it all back together and then heard a rubbing noise in the rear crank case. Ordered a new timing chain and tensioner. Installed them and put it all back together. Fired it up and ran great on the work bench. Took it down and went for a ride and noticed the higher the rpms, the noisier it got. There was a tapping noise on the exhaust side of the valve cover. Removed valve cover. Checked valve clearances, all good. Checked the valve springs, the were a good bit out of tolerance. Installed brand new springs. Same noise. Decided to replace the whole cylinder head with one from a known good bike. Still the same noise. Decided to replace the camshaft with one from a known good bike. Still makes the noise. Replaced lift caps. No change. I’m at a loss on what could be causing this noise. It’s very loud and not normal by any means. Any suggestions would be appreciated. Video doesn’t really pick up the noise good, but it’s there.
IMG_2225.MOV -
By JacobSlabach
i know this isnt an atv but same type of thing. I have a riding mower im fixing and selling for my aunt and it has a dead battery. i jumped it off my atv and when i turn the key nothing at all happens. i tried jumping the relay still nothing. this is with the seat down. you wouldnt think this mower would have issues as its a top-of-the-line brand and almost brand new (aunt found it for a good price, still got tits on tires, just sat for a couple months in a mechanic shop
