STOLEN ATV: Looking For My Old 2005 Blaster Stolen From Shed
Similar Topics
By Fittzy
So I have a Polaris predator 500 and everything works on it but not getting spark and no power going to CDI box. Please help
By Steve Howard
I picked up this ranger cheap because the AWD wasn't working. I checked it out and had 12.5 volts at the diff if I unhook the ground from the harness and run a straight ground from the frame it engages. What could be causing this? Any help would be appreciated!
By mustang
Does anyone have a Suzuki 700 king quad engine that they would sell at a good price? Mine needs building but the price for Suzuki parts and to resleeve the cylinder is outrageous. Thanks
By fortininers
Hi all,
just bought a 2005 Yamaha Kodiak 450. Was curious about any major issues Some of you might of had. Will be using in winter conditions with a snow plow.
thanks!
By David Land
I have an 05 King Quad 700 that has in the past had to have the stator replaced twice. For the past six months it has been down hard as I cannot get it to fire. I have replaced the coil (which is the code that came up) and now I have a friend replacing the stator. I want to see if the new stator does the trick. Drain the old fuel, and replace with 100% Ethanol free fuel, and see if that does the trick. The local Suziki dealer will not work on it as it is over 10 years old. So the nearest dealer is 90 miles away. The last thing I can do after that (provided the other fixes do not work) is replace the ECM/ECU. I also read that there was a recall on the ECM/ECU, so I need to check on that. All of the grounding has been checked, so if anyone has an idea, I would greatly appreciate the insight.
Kindly,
David
