    • By pastorjeep
      Need a little help fixing a no spark issue. 2002 BT with the 2 wire ignition switch. I have 4 stators and 2 CDI's and 3 coils to test. The new stator reads 218 ohm, and .2 ohm, the one that came out of it reads 50K and .2, the other is 132 and .2. All of the coils are 0.00 ohm, and there is no way to test the CDI that I know. I have also confirmed the replacement stator pins match the factory locations. I did try to test milli-volts at the coil to see if it was getting any signal from the CDI but nope. IDEAS?
    • By Tim Keiper
    • By drag_on
      I have 3 atv's 2 have winches , the problem I sometime have is loading onto the trailer if the bed is wet or of frosty. there have been times the winch is needed. but , what to do if the w/o ATV  or any other perhaps dead ride needs to go onto the trailer . 99.5%  of it came from harbor fright.
    • By shorty
