2012 Yamaha YFZ450r Fuel Problems
By Brantley11
Hey everybody,
Here is where we sit:
New 93 Non Ethanol Gas
New Spark Plug
Bluish white spark
Good Compression
Here are the readings:
By JohnnyB
Greetings,
By Gwbarm
By semicolon
By bighoss
