My brother wrecked my 07 vinson 500 yesterday tore up the front suspension pretty good, rim cracked tire slashed, tie rod bent into a u shape, and the front suspension pushed back about 2-3 inches towards the back of the atv. Im trying to find parts cheap as possible does anybody know if parts off a 02 vinson 500 will fit my 07? its the front right that has the damage, i found on ebay the front upper and lower arms with bearing for $60 if they will fit mine it would be great... also does anybody know where i can find a possible used rim and tire and tie rod, everything i find is super expensive, i searched ebay they only have like racing tie rods
So 2 weeks ago sunday i had a accident on my 86' atc250r. Hit a water hole wen i was riding the trails in six gear , i went over handle bars and landed 6 feet ahead of the trike. <Trike ended up in some pine trees some what screw up. Only minor damage to radiator, shroud, front fender, and shifter shif lever. i fractured 3 vertbras in my neck. Kinda lucky. Im not paralyzed or dead, as DOC put it. Got 4-6 weeks off work, and found out that as uv next monday im laid off for 30 days. (:>(::::::::::::
This video was submitted to the QUADCRAZY Video section by quadmaniac.
Description of Video: Quad accident in Kavos
Video Tags: Quad accident in Kavos
http://www.quadcrazy.com/video/video/&v=118311334432
This video was submitted to the QUADCRAZY Video section by admin.
Description of Video: Fire Fighter Fire Accident
Video Tags: fire
http://www.quadcrazy.com/video/video/&v=120174547185
