Trx 450r clutch troubles!
Similar Topics
By mustang
Does anyone have a Suzuki 700 king quad engine that they would sell at a good price? Mine needs building but the price for Suzuki parts and to resleeve the cylinder is outrageous. Thanks
By Stephanie Webb
I have a 2000 500 quadmaster lta an just rebuild the gear box an my high gear is like nuetral will not move but all other gears move nothing looks broke just need some help cant figure out what gear that would be or if it could be the shifter fork
By NoahJakavi
Hello i have a linhai 300 of the 2004+- era. I had a cluch problem so we changed it. After changing it has a hard time to start going. When you pop it into gear and press the gas it barely drives but when it starts going about 20km/h it start driving well the acceleration is normal and everything do you have any idea of what could be the problem
By texaskaw
fighting this thing for a month now.No spark at plug.
New ignition coil,pick up coil,stator,reg/rectifier,all new wiring.Started it up today rode for an hour shut it off.Tried to start later wont start.pulled plug wire it firing a blue spark while starter button is pressed.Tried new plug no change. It stared a couple times an ran for few seconds then died.Will CDI act this way? The reg/rectifier get pretty hot is this normal?
By Serdrix
I have a Polaris Express 300 2 stroke. Finally got the engine running smooth with everything tweaked correctly on the carburetor.
I have now moved on to shifting the gears.
I have had this atv for a long time and high gear was always a pain in the ass to get to go into gear, reverse was okay and low was best.
You could always feel low go into gear.
A couple of months ago the spark plug cap went bad while I was trying to figure out the issue with shifting into high. At this time I put fresh gear oil in and never drained the old because it literally looked empty.
Fast forward to a couple of days ago. I finally got everything running but shifting into low you cant really hear grinding gears but it doesn't jerk like it used to when shifting into low and half the time it wouldn't shift fully.
Reverse would move but completely grinding, and high of course is still the pain in the ass.
All 3 gears when shifting into clicks like it got a good shift, not a click on the gears or anything, just a normal click that your in gear so I know I am not loose on the shifter rods.
I checked the gear oil and it was sort of milky, like barely and had bubbles. This means water is in it so i am going to drain the gear oil today.
What I am wondering is could the bad gear oil be the reason the gears aren't going in fully? I highly doubt it because of the symptoms with some gears grinding and others not going into gear at all like high.
Just need to know what the causes could possibly be.
Thanks!
