I need some help y’all, I bought a 450r, 2005 and I was riding it and unfortunately got stuck, I had no clutch control at all, I put it in gear and release the clutch, it doesn’t go anywhere, I select through all gears and it won’t move, i can rev it out, I just bought a clutch kit, but I am sorta new to this whole scene of race quads, I always had a 4x4, so any help will be much appreciated thanks.
@quadnut20 is a 400EX man...Perhaps he can provide some insight into this?  I would assume that a shift fork has moved or some other hard part is disengaged.  If it was pulling and now it's not pulling at all, that tells me it's probably not really going in gear.  Or the clutch is stuck in the "engaged" position and not releasing.  I had a 400EX but never dug into the clutch.
Ive got the same quad since I bought it new in 05 Ive never had a issue with the clutch ! Whats it doing ? is ur cable working right or out of adjustment ? pull the cover off and youll be able to see if it working proper
    • By quadnut20
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By Eisenmatt17803
      Good Morning!
      Thanks in advance.
    • By quadnut20
    • By mikeexplorer
