Hi guys im new here and ive been doing alot of research on my polaris predator i was wondering if anyone on here has wired a different cdi up on there quad? Not a direct replacement that would simply just plug in. I know my white an w/red wires go to my pulsar my green an blue go to my reverse coil but im unsure which is + and which is ground also brown/w is a ground correct? What about purple? Black goes to my kill switch and red is my 12v supply........then ive got yelloww/red , yellow / yellow that goes to my rectifier..........any input on this subject is greatly appreciated thank you all
  • Ajmboy changed the title to 2006 Polaris Predator 500cc CDI Wiring
I have the 2003 manual i thank you for your time and its nice to be a member of the site...........the two years are different cdi's the 06 has 1 extra wire the 03 was 8 pin the 06 is 16 but only 9 pins are used. I have a cdi and harness from a sawtooth im trying to keep the pred with its original harness and just incorporate the sawtooth cdi i know it can be done. All cdi boxs do the same thing some are just ac and some are dc which is what the pred is. Ive got a cpl other cdi's but i think the sawtooth is my best bet. If i was rich id just buy a oem unit but i dont got it like that unfortunately so i gotta try and get by with what i got! Any input or ideas on this i encourage an thanks once again ......
    • By noticon75
    • By Elk
      2002 Polaris Magnum 325
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By cruteg8
      Does anyone know  the orientation of the bell crank for scrambler 400 2x4 it was not hooked up when I bought quad the way  i put it high goes into reverse and vise versa I flipped it 180 but that put  the shift rod at big angle and it just kinda grinds into gears so dnt think that is right either pretty sure it has to be the exact orientation and the rod adjusted accordingly but I cant seem to find it anyone knows please help
