My Arctic Cat ATV started sputtering and backfiring and losing power on acceleration and sometimes die. It idles perfectly. I thought it may be the carburetor float sticking and would knock on the bowl and it would run great again for a while. It then started doing the same thing but I began hearing a loud knocking like low octane knock. This is intermittent and does not knock all the time. Thinking it was the carburetor float and possibly an obstruction in the jets I cleaned the tank and carburetor and put a new kit in. Still had the same problem. Bought a new OEM carburetor It still has the same problem at any adjustment? It also seems to improve a small amount when carburetor is disconnected from the filter system. I am starting to think it may be something else causing this possible a Coil or electrical? I would appreciate an experienced reply. I do have automotive shade tree experiences but this has me scratching my head. Thanks in advance!
Welcome to Quadcrazy @Rick Robinson
its a pain in the as* but I would check your flywheel.  There have been problems with the magnets coming loose and spinning inside the flywheel. The epoxy that holds the magnets fails and they slide out of position causing the symptoms your having.
The flywheel magnet problem was common on years 2005-2007 models. He did not post the year of his machine. My first quad was a 2007 Arctic Cat and I did not have the problem. Guess I lucked out.  It is something he needs to check as it can cause his symptoms.
Mike
I seen that with not posting the year.
 I'm the last one to go into an engine without checking all the basic non invasive problems first and would continue to do so. Use this as a last resort if he gets nowhere with the other stuff.
But if it is this problem and one of the magnets comes out.... oh boy.
Also pulling that cover off is not so bad anyway.
Edited by Frank Angerano
Welcome to QC !!
    • By oxidized_black
      I have noticed lately that the ATV tires i generally buy have upped in price quite a bit. The Kenda EX that i generally get are sold out and not available at this time, the EVO which is usually my second choice has increased 50.00 on a set of 4. The HTR Kendas best tire is now 150.00 per tire. Even the Sun F have increased but not so much as the others.
