  • Admin changed the title to 2014 Polaris Phoenix 200 will not go forward
19 hours ago, Marc DiTomasso said:
The Polaris phoenix 200 will not go forward only in reverse, it just happened out of the blue, I’m wondering if someone could help me figure out what it is
Does it rev out in forward? Did it go through any water? Like @Frank Angerano said, check the belt..
Yes, he said he went though water, and yes it revs out in forward. Do you think I should change the belt? It is the original belt.
4 hours ago, Frank Angerano said:
No i was thinking more along the lines of seeing if any small pieces of gears ⚙️ Come out or any burnt smell etc.
Ok, I’ll try that and change the belt. Because I never heard any sort of grinding.
But the machine does go in reverse, do you think it still could be the belt? When you put it in forward and push it it doesn’t really seem like it’s in gear, when you put it in reverse and pull it backwards it kind of bucks a little bit, do you think the belt would allow that?
Thank you guys so much, it was the belt Housing was soaking wet and the belt would not grab the clutches. I took it apart dried everything up put it back together and is working fine, again thank you for everything, you guys are the best!
  • 6 months later...
 I had this problem over the weekend. The ATV would not go forward, it would go in reverse until it got under strain (backing onto a trailer). Researched it found this page. After reviewing the suggestions, I pulled the drain plug, a lot of water came out. No smells, no metal shavings just dirty water. I let it dry over night. Cranked it, pulled it off the trailer, rode it for a mile easy and then climbed about a 5 - 8% grade with no problems.
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By OldATVowner
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
