Only have about 60 hours. Sometimes and most often when I just accelerate I'm hearing a metallic clunking noise that seems to coming below the gas pedal or towards the lower front section of the UTV. It does not sound horrible but it really does not sound good. It only lasts for about 1 or 2 seconds. Could anyone please give me any ideas what might be happening? Thank you.
Edited by daynick
Forgot Titlel
Sounds to me like a CV joint slipping.  Prob going to need an axle.  Not a huge deal to fix.  Make some tight U turns in both directions and see if you hear the clicking.   If so then its definitely an axle.
    • By canamKID
      Anybody familiar with this noise from my quad? Just started.  It temporarily goes away when I attempt to shift into another gear but shifting has gotten harder too.
      20260711_150338.mp4
    • By TomJulio
    • By TomJulio
    • By Olchap
      Thank you,
      Olchap
    • By shorty
