it came pre-disassembled so this should go fairly quickly...
took 4 pumps of grease and off it popped, its a can am puller the thinner tipped one. it bottomed in clutch before crank so the grease hydralic locked and off it came!
never dealt much with these power bloc clutches. a few on older ski doo thats it.
  • Admin changed the title to 1992 Polaris Trailboss Rebuild
after a couple hours of cleanup, there was alot of aluminum transfer and is already at .40 over. im gonna run it as is with those couple scores. i ended up taking the die grinder through the exhaust a bit just because of the carbon and melted piston
  • 9 months later...
On 3/28/2021 at 1:15 PM, green53 said:
What rear tires do you have on that bike?
It came with pure sports bandits, very popular in the 90s 😎 I added a set of ams sand snakes that were all folded up from shipping for ten years. They cracked terribly but I added a little slime and they sealed right up 👍🏻
On 5/25/2021 at 7:30 PM, SashaGraves21 said:
How did you hook up your carb?
I ordered a aftermarket replacement intake manifold, and used the original air box and boot 👍🏻 It needed a throttle cable so I replaced with aftermarket, be sure to set and double check your oil pump setting when changing cables, choke cable is factory, and all fuel lines and oil lines are new as well. If you have a project like this pick up a copy of the service manual, I have both the clymer and the factory Polaris. They will be a big help 😎👍🏻
Nice wheeler. I've fixed up a couple old Polaris's recently. This one is my wife's. Next is my son's 350L. Just got the cylinder back from Rick Ritter. Long wait, but worth the quality.
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
      Sportsman 1000 wiring diagram
