Similar Tagged Content
By Admin
Looking for Honda ATV VIN (Vehicle Identification Number) Number Decoders? Once you find your ATV VIN number off the tag on your Honda ATV, you can go to all kinds of websites that have VIN Decoders available. The best ones are backed by the Honda ATV manufacturer, however there are plenty of aftermarket Honda ATV VIN Decoder websites on the web. This topic will stay pinned and if you find any to add, please do it with a reply.
The following Honda ATV VIN Decoder websites are available where you can just enter your VIN number and it will shows you some of your ATV model details:
CARFAX https://www.carfax.com
By Brent Mason
I have worked about 4 weeks on my Griz600 and have burnt 2 CDIs up ! I added a wire harness and stator and It starts but runs erratically like spark timing is off ! So I would like to try another CDI but I don’t want to Pay an arm n leg ! Anybody have one ? Thanks
By Brent Mason
I have been trying to get my Griz600 running right for 3 weeks ! Grandsons used it and it quit running , no spark ! New stator etc and started but ran terrible ! Found a burnt capacitor on cdi . Installed used cdi and burnt it also but ran same as other cdi . Came to conclusion wire harness had short so stripped it and found some bad spots fixed and another cdi ran terrible again ! Bought another harness and same rough running ! Checked spark timing with light (put tdc mark on case and on pull start hub) and when it starts timing right on but will jump 25+° retard ! When timing is on tdc marks it has no power ! The stator is new but I am wondering if the pickup coil is triggering incorrectly ? Also had top end apart when I first started having trouble and although rings were good I installed new rings . Also new timing chain and check the valves , they were good also . It kind of seems to boil down to the last stator I installed new ? I have done trouble shooting on quite a few cars , trucks , dirt bikes and ATVs but this is frustrating me ! Just wondering if anyone has any ideas ? Carb was new last yr and I checked it ! I
IMG_4379.MOV -
By Brent Mason
IMG_4272.MOV Originally had my griz600 stop running and then wouldn’t start ! After testing all coils , valve lash , compression (115psi) and all tested ok I bought a used cdi . After cdi install it still wouldn’t start (no spark) ! So even though the stator , pulse/trigger and charge coils check within good range I decided to switch the stator etc ! It started but It is very unresponsive on throttle and acts like it is running in 2 Different spark timing ! With slight throttle it will take off good but instantly go into a very different running mode with no power like timing very retarded but it will switch back to running good for short period then bad again ! Since I replaced the stator and it started I then decided to install the cdi I replaced and it did the same thing ! Also I noticed the Used cdi I Took off had a capacitor that had swelled and extruded from the back of the cdi . I had always heard and I believed that when these CDIs go bad they machine will quit and will not run . Is that true ? I also checked the cam/valve timing and its ok ! Checked with timing light and it does fluctuate on idle ! I am thinking I have 2 bad CDIs . I also switched the trigger Coil wires and would not start then . Man , this thing ran good before and I am confused ! Video below may help !
IMG_4272.MOV -
By Brent Mason
1998 Grizzly600 ! Slowly died then wouldn’t start ! All coils check good ohms ! Checked ac voltage from source coil get OL ! Is the source coil bad ?
Similar Topics
By oxidized_black
1981 Honda Odyssey FL250 Service Manual
http://rapidshare.com/files/4015559117/1981%20Honda%20Odyssey%20FL250%20Service%20Manual.pdf
1984 Honda TRX200 Service Manual
http://rapidshare.com/files/1721362828/1984%20Honda%20%20TRX%20200%20Service%20Manual.pdf
1985 - 1986 Honda TRX125 Service Manual
http://rapidshare.com/files/2121257077/1985%20-%201986%20Honda%20TRX%20125%20Service%20Manual.pdf
1985 - 1987 Honda TRX250 Service Manual
http://rapidshare.com/files/4232247802/1985%20-%201987%20TRX%20250%20Service%20Manual.pdf
1985 Honda Odyssey FL350R Service Manual
http://rapidshare.com/files/1038546047/1985%20Honda%20Odyssey%20FL350R%20Service%20Manual.pdf
1986 - 1987 Honda TRX70 Service Manual
http://rapidshare.com/files/1309032115/1986%20-%201987%20Honda%20TRX%2070%20Service%20Manual.pdf
1986 - 1988 Honda TRX200 Service Manual
http://rapidshare.com/files/949101394/1986%20-%201988%20Honda%20TRX%20200%20Service%20Manual.pdf
1986 - 1989 TRX250r Service Manual
http://rapidshare.com/files/1348342215/1986%20-%201989%20TRX%20250r%20Service%20Manual.pdf
1986 - 1989 TRX350 Foreman Sevice Manual
http://rapidshare.com/files/3630673106/1986%20-%201989%20TRX%20350%20Foreman%20Sevice%20Manual.pdf
1987 - 1988 Honda TRX250 Service Manual
http://rapidshare.com/files/4216058340/1987%20-%201988%20Honda%20TRX%20250%20Service%20Manual.pdf
1988 - 1994 Honda TRX300 TRX300FW Service Manual
http://rapidshare.com/files/2869775313/1988%20-%201994%20Honda%20TRX%20300%20TRX%20300FW%20Service%20Manual.pdf
1989 Honda Pilot FL400R Service Manual
http://rapidshare.com/files/2360735449/1989%20Honda%20%20Pilot%20FL%20400R%20Service%20Manual.pdf
1993 - 2000 Honda TRX300ex Service Manual
http://rapidshare.com/files/124180871/1993%20-%202000%20Honda%20TRX%20300ex%20Service%20Manual.pdf
1995 - 2000 Honda TRX300 Service Manual
http://rapidshare.com/files/3283588559/1995%20-%202000%20Honda%20TRX%20300%20Service%20Manual.pdf
1995 - 2003 Honda Foreman TRX400 Service Manual
http://rapidshare.com/files/3572272247/1995%20-%202003%20Honda%20Foreman%20TRX%20400%20Service%20Manual.pdf
1997 - 2004 Honda Recon TRX250 Service Manual
http://rapidshare.com/files/3337525946/1997%20-%202004%20Honda%20Recon%20TRX%20250%20Service%20Manual.pdf
1998 - 2004 Honda Foreman TRX450 Service Manual
http://rapidshare.com/files/2663992981/1998%20-%202004%20Honda%20Foreman%20TRX%20450%20Service%20Manual.pdf
1999 - 2002 Honda TRX400ex Service Manual
http://rapidshare.com/files/1631661899/1999%20-%202002%20Honda%20TRX%20400ex%20Service%20Manual.pdf
2000 - 2003 Honda TRX350 Service Manual
http://rapidshare.com/files/3664297190/2000%20-%202003%20Honda%20TRX%20350%20Service%20Manual.pdf
http://rapidshare.com/files/2182711541/2000%20-%202003%20Honda%20TRX%20350%20Service%20Manual.zip
2001 - 2003 Honda Rubicon TRX500 Service Manual
http://rapidshare.com/files/3265452867/2001%20-%202003%20Honda%20Rubicon%20TRX%20500%20Service%20Manual.pdf
2001 - 2005 Honda TRX250ex Service Manual
http://rapidshare.com/files/4243708028/2001%20-%202005%20Honda%20TRX%20250EX%20Service%20Manual.pdf
2001 - 2006 Honda TRX300ex Service Manual
http://rapidshare.com/files/682344164/2001%20-%202006%20Honda%20TRX%20300EX%20Service%20Manual.pdf
2003 Honda Rincon TRX650 Service Manual
http://rapidshare.com/files/3906606110/2003%20Honda%20Rincon%20TRX%20650%20Service%20Manual.pdf
2004 - 2005 Honda TRX450r Service Manual
http://rapidshare.com/files/1981833062/2004%20-%202005%20Honda%20TRX%20450r%20Service%20Manual.zip
2004 - 2006 Honda Rancher TRX350 Service Manual
http://rapidshare.com/files/1111406663/2004%20-%202006%20Honda%20Rancher%20TRX%20350%20Service%20Manual.pdf
2004 - 2007 Honda Rancher TRX400 Service Manual
http://rapidshare.com/files/1969053081/2004%20-%202007%20Honda%20Rancher%20TRX%20400%20Service%20Manual.pdf
2004 - 2009 Honda TRX450r Service Manual
http://rapidshare.com/files/2621155546/2004%20-%202009%20Honda%20TRX%20450r%20Service%20Manual.pdf
2005 - 2006 Honda Foreman TRX500 Service Manual
http://rapidshare.com/files/2291577524/2005%20-%202006%20Honda%20Foreman%20TRX%20500%20Service%20Manual.pdf
2005 - 2008 Honda Rubicon TRX500 Service Manual
http://rapidshare.com/files/1844257008/2005%20-%202008%20Honda%20Rubicon%20TRX%20500%20Service%20Manual.pdf
2005 - 2009 Honda TRX400ex Service Manual
http://rapidshare.com/files/1972972957/2005%20-%202009%20Honda%20TRX%20400ex%20Service%20Manual.pdf
2005 - 2011 Honda Foreman TRX500 Service Manual
http://rapidshare.com/files/761113354/2005%20-%202011%20Honda%20Foreman%20TRX%20500%20Service%20Manual.pdf
2005 - 2011 Honda Recon TRX250 Service Manual
http://rapidshare.com/files/1279728571/2005%20-%202011%20Honda%20Recon%20TRX%20250%20Service%20Manual.pdf
2006 - 2011 Honda Rincon TRX680 Service Manual
http://rapidshare.com/files/524040045/2006%20-%202011%20Honda%20Rincon%20TRX%20680%20Service%20Manual.pdf
2006 - 2011 Honda TRX250ex Service Manual
http://rapidshare.com/files/3511982365/2006%20-%202011%20Honda%20TRX%20250ex%20Service%20Manual.pdf
2006 Honda Rincon TRX680 Service Manual
http://rapidshare.com/files/556472988/2006%20Honda%20Rincon%20TRX%20680%20Service%20Manual.pdf
http://rapidshare.com/files/2453136435/2006%20Honda%20Rincon%20TRX%20680%20Service%20Manual.zip
2007 - 2009 Honda TRX300ex Service Manual
http://rapidshare.com/files/4113217842/2007%20-%202009%20Honda%20TRX%20300ex%20Service%20Manual.pdf
2007 - 2010 Honda Rancher TRX420 Service Manual
http://rapidshare.com/files/3744811371/2007%20-%202010%20Honda%20Rancher%20TRX%20420%20Service%20Manual.pdf
2008 - 2009 Honda TRX700XX Service Manual
http://rapidshare.com/files/1240979778/2008%20-%202009%20Honda%20TRX%20700XX%20Service%20Manual.pdf
2009 - 2011 Honda Rancher 420 Service Manual
http://rapidshare.com/files/3449849282/2009%20-%202011%20Honda%20Rancher%20420%20Service%20Manual.pdf
By JacobSlabach
Hey I picked up a pit bike and a foreman for 800 the pit bike was running but the foreman was locked up. Sold the pit bike but when I took the top end off the piston I only found half a piston left. So knowing the rest of the piston was down in the crankcase I knew it had to be pulled and gone thru completely.
to pull the motor I went ahead and pulled the rear end off and unbolted the front diff to pull the drive shafts and pull the motor. Now I have the motor torn down completely and have all the parts of the piston removed. I know the rod and crankshaft is shot (heat discoloration and too much up and down play rod to crankshaft).
***so I’m wondering while I have the motor apart what should I check for? I know this motor died from heat as the oil in the head smelled like popcorn. So what should I check to make sure I fix the issue (overheating I assume) and not just the symptoms (blown up motor lol).
Here’s some pics
By Quad king
I am not sure what is wrong with my King Quad. I had a new carburetor put in 6 months ago, just replaced the fuel pump and added an in-line fuel filter in. I have been trying to fix this quad for a while now and do not know what is wrong with it. It idles fine and runs great as soon as it is fired up, you can Rev it and stay in first gear with 100% power. As soon as I drive 10 feet it looses all power, I mean it is sputtering and doesn't move at all, but when I let off the gas after it sputters it idles fine. I will attach a video of what it is doing.
Snapchat-1290161440.mp4 -
By Brennon Heflin
So I bought a 2000 quad runner 250. I'm having some issues an wondering what it could be I replaced the pet cock valve an the fuel filter an pump inside tank I also put a voltage regulator on it. The problem I'm having is that when u give it half or more throttle it bogs down an loses power what could it be the bike is almost like new an cant figure it out any help would be great
By Marcelo
I have a problem with my 1986 honda 200sx. It idles good, but for some reason ittle start revving high. It also drives by itslef when it does that. It also wastes a lot if gas, but im more worried about the iding issue. I have the idle low right now so it wouldnt do that, but when i fix the idle, it idles good, but itll start revving up. Please help me
