Some of the trickier obstacles for quad newcomers to master are whoops. Approach them at the wrong speed or wrong angle and you're likely to end up on your head faster than you can say "whoops."
More...
    • By BillR94
      Just thought I would start a poll on this topic manly because I'm not a fan of belt drives. Just want to know which you prefer.
    • By johndeerefarm
      Is there any way to mod an Outlaw 50 to increase the speed? The size is perfect just would like a little more top end speed. Thanks
    • By p5200
      I added more fresh gas it sat one day now, it's acting up again. Before cleaning out carburetor it wouldn't idle good and had gas leaks from carburetor. Now it idles pretty good but, if I increase throttle speed at a certain amount it starts missing bad. I'm going to try and post a short video. Just about ready to give up on this thing.😒  you can see reflection perking in video.
      20240217_114429.mp4
    • By JPRICE1981
      Hello everyone !! Looking for some help !! Im wanting to check my stator and pick up coil with a ohm meter and cant seem to find a guide that tells me what to read and what my reading should be !! Any help would be great !! THANKS IN ADVANCE !!
