I just got an old YFM200DX Moto 4 and upon checking the oil in the rear differential I took out I assume the fill plug and it fished out old nasty oil. I plan on flushing the oil and replacing but was wanting to make sure if you drain bottom plug and just fill up to the check plug. Only thing I can think of someone filled it up by the breather on top? Plan on unhooking the hose and blowing it out tomorrow. I also do not have a service manual yet. Also right now the diff vent hose just goes up under the tank to nothing. Does it plug into back hole in the air box? Thanks
That’s where my breather hoses go on my 2000 grizzly. Look for witness marks where it is now. If it passes under a little bar and the rubber is really kinked there like it’s been there for a while good chance that it is in its spot.
  • 2 years later...
  • 3 months later...
I usually use Mobil Delvac 75w-90 synthetic in mine, our temperatures here can be 110 F in summer, and down to -10 F in winter. and it seems to work well in all our drive gearboxes. It doesn't hurt that I often get it free from work when it goes past the shelf life for use in our aircraft gear drives!
      I have had my new tires for a while, chronic procrastinator, decided it was time to get them mounted up. Against my better judgement i decided to mount them myself.
      I got one of these Harbour Freight manual tire mounting machines, mounted it to a half pallet to make it more portable. Very impressed with the quality and amount of tools that came in the kit for a low price point.
      The bead breaker worked very well, i wasnt sure it would be able to do it, i think these tires are original to the bike its a 2004, but with enough lube, mothers concentrated car wash straight, it finally broke the bead.
      Tire fit very well on the machine and it tightened down good.
      The extra long pry bar that came with the kit worked well to get the outer rim of tire off.
      Half way there, half way there no issues, then it got serious.
      I pulled and i tugged had 3 prybars working this thing and it wouldnt budge no matter what i tried it would not come off, until i got the grinder out and cut it off. Im sure most of you see what the problem was. I didnt notice it until i was too far in to change direction. On this particular rim the tire goes on and off from the back side of the rim, not the front like what i was used to. The back side is the low side. Plus to add to the problem tires were old and not very strechy, i have a greater respect for how well these ATV tires are made with well reinforced sidewalls, even with the grinder it took me a minute or two to cut through it, of couse i was being very careful not to nick the rim. Anyway the HF machine worked well and the tire is off, hopefully the next one wont be this bad. Lot of hard work for an old man, glad i can still do it.
      Now for the fun part , cleaning up the old rim, years of stop leak and slime caked on the inside, that stuff dries hard, the little Milwaukee is good for getting into tight spaces, but wasnt quite up to the task.
      Needed a few more RPMs.
      Old rattlecan paint just flaked right off. Now time to decide on a new color, tired of the boring gray. More to come!
    • By Southbitz
      hi im new to this but have done oil drains on my dirt bike
      but I took wrong drain bolt out of my quad.: Ive emotied the gear box oil and what appears to be my chain tensioner part. Drained oil out both plugs thinking it was my engine oil!!
      I’ve refilled the gear oil from a oil point and not the engine oil as I’ve done that through the dipstick refill point… im just really worried about the oil that came out the tensioner part .. will there be a refill point for that separate from gear oil refill. Ives struggled for 4 days for information and goung round the bend..  Chinese quad is a 10ten 180 RXR
      please if someone could answer this as I’m worried to run the quad until I’m sure I don’t need to find another fill point for the tensioner part ?
    • By tds7
      Do any have any experience replacing 2001 Big Bear 400 Front Differential Input Shaft bearing and seal. Getting ready to buy one but the seal and bearing are bad. Any help would be appreciated.
    • By DPDISXR4Ti
      Thanks...
    • By qcm413
      Hi,
      Thanks for a newbie on this site !
      i have grinding noise in my front differential. the front right wheel is turning and the left is try to turn but no movement and make sound like a gear broken. somebody have any idea ? not enough oil in diff ?
      thank
