Rebuilding a Zhejiang Yongkang 500W ATV - Need help with braking
By rjsummer
By Arizona
Just recently bought a dead 06 Eiger, Can someone post or send me a wiring diagram for it:?
Need to check all wires, no power in most places, Cant seem to read the ones from online manual,
too blury and cant tell wire color. Just too small. Thanks Az
By Peisledder
Hello, can someone help me? I have a MAP error code 102-3, and the MAP has 4 wires: light blue, orange, purple, yellow. I’m getting different results on what the wires are. I don’t have wiring diagram. Can someone confirm which is ground, 5v, MAP, and Temperature?
By BillR94
By BuckBilly
Just thought I would start a poll on this topic manly because I'm not a fan of belt drives. Just want to know which you prefer.
