I have a 2008 loncin desert storm that wont stay running.
When it ran it ran rough and backfired a lot.
Now it will only start with throttle and there's a lot of unburned fuel (white smoke), there's also compression comming out the airbox. Is it the carburetor that is broken?
4  things  could  cause that problem.   Timing slipped   so  the  intake  valve   is  still partially open  when  cylinder fires ,  Intake  valve  is sticking slightly  open, rocker  arm   is too tight  and holsding  valve slightly  open  and finally,  a burnt  intake valve valve allowing  combustion gasses  to  blow back.
Most  likely  is a timing slip  or  valve  lash on the  intake valve is too tight .
  • 3 years later...
    • By Mister907
    • By Brent Wright
    • By HeWasRidinDirty
      The one I need to replace has a 2 wire plug coming out of it. Searching eBay I see tons of them with only 1 wire . WTH???
