2011 Brute Force 750 I. Having an overheating issue. When fan sensor is unplugged by thermostat fan will run and cycle. When its unplugged it will not run and cycle. Need help. Really dont want to take to dealership.
  • Admin changed the title to 2011 Kawasaki Brute Force 750 Overheating and Fi flashing light
  • Ajmboy changed the title to 0 Overheating and Fi flashing light
I think that's normal because when you unplug the sensor it causes and open and the fan defaults to turns on. If its plugged in and not turning on, my bet would be a faulty sensor or fan breaker.
Yes, but when that senor is unplugged it throws an Fi code on the dash and the fan will work but as soon as I plug it back in the fan stops which causes it to over heat both sensor and breaker have been replaced but it still not working. Relay is also functional.
  • Ajmboy changed the title to 2011 Kawasaki Brute Force 750 Overheating and Fi flashing light
Could be the ECM, but hopefully not. There's some troubleshooting the dealer would do. You could refer to the manual and check the temp sensor resistance and output voltage. If you say all else is working, that may be the next step. Do you have the service manual? I just uploaded 2102-2014 which is the closest I could find:
Modern ATV's remind me of modern vehicles.  My wife's 2015 Mustang was having power loss at highway speed but would take off normal.  2 days of troubleshooting, no codes thrown, settled on it being a low pressure fuel pump and resigned to taking it to the dealer.  Noticed last night brake lights stayed on.  So I shimmed the brake light switch and fixed the power loss...guess it was triggering pseudo limp mode.
I bring that up to say....modern ATV's are too darn complicated and hard to troubleshoot. :)
  • Haha 1
    • By carkivey3
    • By fwsamm
    • By mmikesell
    • By Dsluder
