I'd start by connecting an inline spark tester to it so you can watch ignition while it's running. When the engine quits, so you still have spark? If so, then it's on to checking out the fuel system.
I do have an inline spark tester and will check that out this weekend as its currently pulled apart again i went ahead and prdered a fuel valve (old one had just started leaking right after i originally posted) and another fuel pump both will be here friday abd my buddy has a brand new caltric carb im going to put on it at the same time so hopefully i can rule the fuel system out all together. Im also cleaning my tank and the pickups in it at same time hopefully all works after. Ive tested the etc and its working right so im pretty sure its not the problem.
Sent from my LM-Q720 using Tapatalk
Sounds fuel related. Too much or too little fuel to keep it going. You would smell the gas if it was too much, my guess its too little. I would add a clear fuel filter before the carb to see if any debris may be getting to and clogging up the carb. Takes very little to cause a lot of headache...
Sent from my SM-G973U using Tapatalk
    • By realpilot
    • By OldATVowner
    • By flyinbrian365
      What's Covered:
    • By Rockbottom
      What should i test next?
      thanks ahead
