Boondockers Nitrous Kit- $650 OBO shipped.
This is a Boondockers nitrous kit that i paid $850.00 for and I only used it at 2 trips to the dunes. It is a fun toy to have, i beat banshees and raptor 700's with no problem. I have a water temp. gauge and the motor never got any hotter than normal when I would squeeze.
My method was when I would shift into third I would hit the button for about 2 seconds and then again when I hit fourth. I was usually far enough ahead that I really didn't need to hit it after fifth gear. Like i said it was really cool to have, don't really want to get rid of it but my girlfriends quad needs a new front end. I will miss it but my girlfriends safety is a little more important to me than all the looks i would get with the nitrous bottle hanging in front of the quad. My quad just has a pipe, k & N with no lid and re-jetted. I will include the k & n filter so you don't have to worry about drilling the hole in the back of it for the manifold. ( The hose coming from the bottle to the solenoid is steel braided.)
NEED THIS THING GONE. IF YOU NEED PICS EMAIL ME AT [email protected]
    • By Gtc4d
      Thanks.
      Todd
    • By ButchM
    • By dkgg5755
    • By jordan_ATV
    • By shorty
