I'm looking to upgrade to a bigger machine.  I only use my atv when deer hunting and maybe put 5 miles on it per day at most.  Current atv is a 2004 Kawasaki Bayou  250, 2WD, garage kept, nothing special and it still works great.  I'm wanting to upgrade so I can use a small disc for food plots.  I think the 570 would be perfect size.
Knowing the extent of my use, what are your thoughts on the Tracker (Textron) 570?  It's gets me into a bigger machine at a more affordable price than the big name brands.
Thanks for the input!
thats a testron/arctic cat product.  arctic cat lost its popularity when it started using the kawasaki 650 v twin motor which tend to jump time.  other then that id say the old arctic cat atvs are great machines as well as the new textron off-road models.  yes they arnt well known, but from what ive gathered they are right there with the new yamahas and suzukis and even close to polaris in performance and quality.
my personal experience is to buy a gently used atv (mint condition with a couple hundred miles on it) instead of paying the full price just to drive it off the dealership floor but thats just me..
  • 2 years later...
I have a 2020 tracker 570 aka arctic cat atleast engine cover shows its an arctic cat love the machine!!!! But i dont like the oil filter location right next to the exhaust header does anyone know the filter thread pitch i am trying to find a filter relocation kit to move the filter away from the exhaust header and keep oil temps cooler as I feel the additional heat will shorten the life of the engine. I have also wrapped my header with header wrap to keep oil filter temps down let me know thanks in advance
    • By marlon smith
      It seems every ATV i look at to buy used has no title, does everyone loose there title, or do they change hands so often the title is lost in the shuffle. The ones that do have titles are triple the price. I am new to buying used quads is this pretty standard procedure.
      I know all quads are good and tough but thought it might be good to hear opinions as to what member think is the best, from your experiences.
    • By dkgg5755
    • Guest
      By Guest
    • By jordan_ATV
