1986 lt250ef model g and model f difference
Similar Topics
By tacojooper89
Figured I ought to post a little introduction for me and my newly acquired quad. I just recently picked up a 1985 Suzuki lt250ef in pretty rough shape but a good price. Need typical things like tires, tune up, and a couple other things. Came to this forum looking for a service manual and maybe so parts. I'm looking for mostly the rear brake light assembly being as someone apparently decided to remove it at some point and bypassed the wiring. Also any pointers to typical good practices on these would be nice but I like to think I am fairly mechanically inclined. Any help is appreciated, thanks!
By Marcelo
I have a problem with my 1986 honda 200sx. It idles good, but for some reason ittle start revving high. It also drives by itslef when it does that. It also wastes a lot if gas, but im more worried about the iding issue. I have the idle low right now so it wouldnt do that, but when i fix the idle, it idles good, but itll start revving up. Please help me
By William Edwards
I need a carb for my 1986 LT230S. Can't find reasonably priced OEM anywhere. Does anyone know of an aftermarket carb that will work?
Manual says OEM is Mikuni VM26SS
Thanks!
By Viking
There's an electrical cable connected to the front brake lever. The parts list calls it the front stop switch assembly. There is no stop switch on this side of the handle bars. Seems to be activated by the brake lever. Anybody know what it does?
By mjm4jc
Hello eeveryone,
Just picked up an 86 Suzuki LT185 for my daughter, and she's complaining that it bounces so bad over bumps that it nearly throws her off the quad. I have the tire pressures some where around 3 psi. I really can't go any lower than that. I noticed that there isn't anything in the aftermarket world for shocks and springs for this quad. I am wondering what others are doing to soften up the ride. Also wondering if there's a way to fabricate a rear shock, since there isn't one. I appreciate your feedback.
Thanks!
