99 kodiak 400 repair
By TomJulio
My 1992 TRX00 recently stopped firing. I understand this is a common problem. I have ordered an aftermarket CDI unit. TJ
By cruteg8
I was thinking about trying to repair some cracks in the plastics of a Lakota Sport i just purchased has anyone ever tried (U.S. Chemical & Plastics USC GarageTM Flexible Glaze USC-77704 it) https://www.ebay.com/itm/364866165725. i was thinking jb weld for plastic then using this as a bondo that can be sanded smooth
By quadnut20
Just picked up this 2025 Kodiak 700 esp and was wondering if anyone has any suggestion on up grades i should look into ?? I did a EPI clutch upgrade and put bigger tires on it but want to do more !!
By Guest
By RGS
