2003 Suzuki Vinson 500 Gear Indicator
By BuckBilly
By Sportsman500guy
By qcm413
Hi,
thank in advance
By Gwbarm
IMG_4910.mov There is some slack in there but most is taken up by the gear cover,if anyone with history with these machines has had the same problem, let me know your findings. Where i am now im looking for finding replacement honda gears on Ebay and try those. I suspect the original was replaced with aftermarket gears years ago and they just worse quality as the years go by.
By marcosphoto
