I have broken the front fairings and in desperate need of new ones was wondering if the falcon plastics will fit as frame looks very similar if not the same many thanks
did you end up finding your plastics?
  • 10 months later...
I don't know if you've already found a solution for your issue with the plastics or not.  If the plastics are broken, you have all the pieces and they aren't excessively bent  or embrittled from sun exposure, you might consider giving plastic welding a go.  Harbor Freight even carries some tools for the job.  The cheapest looks a bit like a soldering iron with a triangle tip a bit like a clothes iron.  Less than $20.00 for the kit I think.  They also have something getting closer to $70.00 which is a hot air system.  I only mention this because within the last few days I helped a guy repair a cracked greywater tank with one of those cheap kits with a bit of metal window screen type material as a structural reinforcement.
    • By cruteg8
      I was thinking about trying to repair some cracks in the plastics of a Lakota Sport i just purchased has anyone ever tried (U.S. Chemical & Plastics USC GarageTM Flexible Glaze USC-77704 it) https://www.ebay.com/itm/364866165725. i was thinking jb weld for plastic then using this as a bondo that can be sanded smooth
    • By 88classic
      I have (2) sets of brand new plastics available for Honda Rancher 420 2014-2023. These are genuine genuine OEM Honda plastics. One set is white and the other set is green. The boxes these are in are too big to ship.(Unless you want to pay for it. If so, lookup your own shipping rates from 17325 and box size is 58"x35"x18").  $400
    • By TomJulio
    • By toe420
    • By TomJulio
