Hey everyone! Just introducing myself and hoping I can get some insight on where to start. I have an older quad, my guess is about an 07. I know it’s a 700 but I’m having some stalling issues with it after it runs for about ten minutes it will die out. It will start right back up and run but after a minute or two it will die again. Any suggestions on where to start checking things?
Got out with the boy the last two weekends to do some riding and set up for hunting on the new property.
42 degrees this am up there! Set up some new tree stands and cameras to see what’s moving around last week. Got up to pull the card from the cams, well surprise surprise there were some big bucks running around!
Anyway back to the big city grind for another 5 days and we are out of here again Friday night!
I've got an '02 Ford Taurus with 99k miles that's got something loose in the front end but I'm not entirely sure what it is. When under moderate to hard braking there's a quick shaking in the front of the car and the steering wheel jerks in sync with the shaking. Jacked up one front wheel, left the other on the ground, and sure enough the wheel moves when pushed at 3 and 9 o'clock, but not at 12 and 6.
