2017 sportsman 570 sp no spark
By Bobbywolf
Thanks for any assistance.
By jashadams
Snapchat-1142015191.mp4 -
By p5200
By Tuzz
By WyattLemke25
Working on a 2016 Sportsman 570 and it has a new battery and spark plug. No codes, fuses all look good. It cranks for a while and when it starts it will only run for a few seconds before stalling. At one point it was running at 3000 rpm with no throttle input, then it dies. Not sure where to look besides messing with the throttle cable, so suggestions are appreciated, Thanks.
Similar Tagged Forum Content
- 11 replies
- 4,639 views
- 1 reply
- 1,946 views
- 18 replies
- 5,238 views
- 5 replies
- 4,453 views
- 2 replies
- 1,433 views
