Anyone had luck with aftermarket "complete" primary clutch setups?
By Spritee1
not sure where to look next
By Gwbarm
I Ran across this video today comparing an aftermarket to OEM Carb on Suzuki Vinson, thought it might generate some interest, it is quite long but informative.
By justent_88
By hardcastle
By skittle021
Photos:
