I am at my wits end. I cannot get any spark at the plug. I replaced everything. New loom, CDI, Ignition Coil, Regulator, Stator.
To attempt to eliminate kill switch issues, the only connections I am working with are the Stator to CDI, CDI to Coil., Starter solinoid to battery. The regulator is not connected, nor are any switches or other plugs. I have even removed the kill wire from the CDI connector. So I have the bare minimum of a ignition circuit. Yes, I do have a battery connected and earthed to the chassis.
I am getting around 20v AC out of the stator on the red/black, and 0.5v AC on the blue/white (trigger). Same voltages at the CDI connector (input)
I am only getting around 0.5v on the yellow/black out of the CDI to the coil.
I am getting around 0.5v AC at the sparkplug.
Any suggestions?
    • By TomJulio
      My 1992 TRX00 recently stopped firing.  I understand this is a common problem. I have ordered an aftermarket CDI unit.    TJ
    • By HeWasRidinDirty
      I rebuilt the carb on said machine. When I hook up the auxiliary gas tank it runs fine and everything is cool. When I put the fuel tank on and hooked up the lines, it completely flooded the cylinder and even about an inch of fuel in the air box. I'm pretty sure that it comes from the little hose on the petcock and hooks to the top of the carb. WTH is that even for? I mean the thing runs fine on the auxiliary tank, so idk And on the petcock when it's in the "on" position, I get no fuel. The petcock from the bike I took it apart and checked out how it operates. The sharpie marks indicate how it really works. Now the other petcock w/o the sharpie marks is an old one that was leaking that I removed from a Polaris quad. It's exactly the same thing, except the small hose and nipple have been removed. I'm so confused, LOL
    • By jeffrocdx
    • By Rockbottom
      any ideas how to correct
      thanks ahead
    • Guest
      By Guest
