Picked up a barn find that someone had already partially disassembled because the “motor locked up” but they never opened the case. Everything was bagged and labeled, and as I’ve mentioned before- I love a challenge ¯\_(ツ)_/¯
After a couple hours of fun with various pullers and hammers I managed to persuade the magneto/flywheel to come off. Hoo boy what a mess. Then I found an actual rats nest in the clutch cover. ಠ_ಠ
My homebrewed case splitter made from a lawnmower blade. Popped apart to reveal some rusty remains of what appears to have been the reed valve.
Got it cleaned up and started rebuilding.
Managed to find another nest in the airbox- full of hair from a deer. Weird stuff.
Engine back in, and started with the plastics before I went to bed. Not bad for a few hours work and some random scrap parts I had on the shelf. Waiting for a new stator, belt(had to cut it to untangle aforementioned rats nest) air filter and plug to arrive to fire it up ;)
I just acquired a 1987 LT80 Quad Sport that is in excellent condition (only about 10 hrs ride time).  The only problem is it is missing the voltage regulator/rectifier.  Suzuki does not make the part anymore and there are no used ones anywhere.  Would you be willing to sell yours if you cannot get it running?  If not, do you have any ideas as to what I can do to resolve this problem?  Any help would be greatly appreciated.
Googled the part number, and found a bunch of them. https://www.bikebandit.com/oem-parts/detail/suzuki/32800-40b00/b1067523
Honestly, as far as I know, you could use a different, bigger regulator/rectifier. Same with starter relay, a regular old solenoid for a lawn tractor ought to work. You may just need to change a couple connectors to make it fit.
Did you see the part where I said you don’t necessarily need that exact regulator rectifier? Because I think that part might be more helpful than trying to search in vain for a part that does not exist in inventory anywhere.
Thanks for the info!  I'll research that further.  I talked to a couple of Suzuki dealerships a while ago and they did not mention that as an option. I hope it works!  The quad is too mint to junk.
  • 3 years later...
Hello Hagbard,
I recently picked up an LT80 in very similar condition and have torn it down to find similar conditions in the bottom end.
My question is how did you go about cleaning the bottom end and all components as you made it look almost new. Also what all did you just clean and keep vs replacing when putting it back together.
I attached a couple of pics of what I'm dealing with.
Thank you.
    • By middlebrookgt
    • By DemonQuad666
      I'm sure this has been tossed around on here numerous times but with the unveiling of the new KTM fuel injected 2 stroke. Could this be the first step in a come back for my beloved double ding ding machines. Ok lets hear it. Why do you like one or the other??? Myself, I always felt it was the throttle control and Powerband response with the 2 strokes. I know this sounds weird but on a 4 stroke, no matter size or model. I always felt like i was along for the ride instead of in control. I've spent hours on my buds 400EX, even took a new 450r for a spin. before they discontinued them. Blasters, Banshees, and a number of 125's, 250's and even one late 80's Honda XR250R... Results all the same. For me its a comfort and control that im used to with the 2 strokes.... and i love the smell of bean oil... So lets hear it. Im sick of arguing with same two people at work on this issue.
    • By maikytech
      Has 60 psi and motor recent flooded...what the true compretion
    • By That229Yamaha
      Hey guys, I’m new to the forum. What I got is a 2001 Yamaha Bear Tracker 250, got it as a project on trade and the problem I’m dealing with is a “no spark” problem and been trying to hunt down the cause for two weeks. I’ve replaced the stator, pick up coil, CDI, wiring harness, ignition, coil pack, spark plug, solenoid, battery, etc. and I’m still not getting any luck. Even tried bypassing the kill switch. I also noticed two things on this quad, another CDI under the back plastic by the voltage regulator, and a blue and green wire coming from the motor behind  the foot shift, tried to hook it up but it broke off and I’m thinking the broken wire would cause it to have no spark, if not then I need someone’s help on this and wanna see if I can get spark again. If anyone knows why I have this problem, the help would be greatly appreciated.
      Im finishing up on the Big Bear, just tying up some loose ends and its done.
      My next project I actually bought first, but the Big Bear seemed like it was more challenging so tackled it first. Now looking the Eiger over im not so Sure.
      I bought this Suzuki Eiger, almost a year ago, rear wheels locked up, but it ran fairly well. It was so bad that it took 3 Big Guys to get it on my trailer. All the parts were there it ran. He wanted 600.00 and I offered him 400.00. a plus it had the original Kei Hin carb on it.
      You might ask, why would you want something so ugly, it is often referred to as the ugly sister to the King Quad. I actually like the Eiger I have this one and also a 2007. I have riden them before, they are strong a true beast, I am a fairly Big Guy 6' 3" 195 pds, and it fits me good, but what I really like is the wide foot print and low center of gravity , not so easy to turn over.
      So I get it home and I don't have 3 big guys to help me get it off my trailer, but I do have a John Deere, hooked it up and drug it off the trailer,an afterthought I should have used a couple of furniture moving dolly's under the rear wheels, oh well. Maybe I didn't ruin the already stuck rear end or transmission I was sure which, I was fairly sure it wasn't locked brake drums, after all that they should have popped free.
       This is what I have done so far. It's off the trailer I took the drive shaft bolts loose, they were tight, had to get a 3 foot cheater, I thought they were going to break. Got them out and now I can roll it around. I checked the shifter, this is a manual shift Eiger LTF400F. Foot shifter moved didn't seem to be going to any gear, but it was hard to tell, the shifter on the tank which has Low, High, and Reverse did not move. I took it apart and oiled it up good still wouldn't move. Thought the cable was stuck so I unhooked it from the linkage and cable moved freely. Looked at the linkage closely and it was stuck. I tapped it lightly, very lightly , with small hammer and it freed up kind of, but still stiff. I could tell this side cover had been off before and put back very sloppily. This is kind of where i left off except the plastics are all off, you might have seen me working on them in another post. Nothing I have done so far has helped, my next step was to take the side cover off the engine to see what's going on in there, but installing my Granite counter top, numerous honeydews, and the big bear kind of slowed down my progress. I did determine that it wasn't the rear end, that's actually what I thought it was going to be. If anyone has any ideas, they would be appreciated.
