it will give you gains for sure.. when you put on an aftermarked intake and exhaust ( or even taking out your sparky) your going to need to add more fuel.. or you will be running lean, and damaging you engine... the pc will give you full control of the fuel curves.. totally adjustable.. and if your interested in the pc the best place and cheapest is Fuel Moto USA $259 shipped. thats where i got mine.. they will even put a map on it with your mods... but one thing to consider is that if you really don't plan on going into the motor you will be fine with a dobeck controller.. such as an hmf etc... to completely dial in a pc it should but installed on your bike then adjusted on a dyno.. you can get in the ball park with other peoples maps but never right on.. got to remember every bike is different..
Thanks guys, but it' s too bad cause here in canada it costs 399.99$ I'm looking everyday on ebay for a cheaper one they are around 290.00$ to 300.00$ the same.....but i know in the long run i will get one!!
    • By Adamb2025
    • By davefrombc
      Anyone  carrying  a power box when  camping with their ATV?  I built  a custom  one.  I  used a  marine  battery box that  has 2  50A Anderson Grey connector  outputs (  changed one of the greys to a red), an accessory socket  and2  USB outlets,and a battery  voltmeter ..  I  added a Pure sine wave 1,000w inverter to it and A red 120A Anderson connector to the  output  posts.. To  charge the  100Ah LiFePO4 battery  I  put in the box, I added  a DC to DC charge adapter that I  made input connectors for to allow charging the battery from a vehicle's  accessory socket  or a solar panel.
      It  was a fun  project.. Besides  having a  1,000w power box for  120V ac , USB   and  12v accessories using the 10 A socket.  I  have  50  A  Anderson connectors  and the 120 A connector  to run  things like a  12v electric outboard   for fishing  trips .  The LiFePO4  battery  only allows a max output of 100A  so  it  can't be used for something like jump starting,  but  it  is half the weight and  delivers twice the capacity of a lead acid battery running accessories..  Commercial pow2er  boxes  don't  deliver  high draw 12v output to run things like  the  electric outboards.   That's one reason  I  custom  built  mine.   One box that serves for both camping and fishing.
    • By dkgg5755
      Im not getting 12v to ignition switch with key off or on I've jumped brown wire from starter relay to positive and neutral light comes on and push button start works. Can't figure out where to go from here any help appreciated l.
    • By Need-help-with-quads
    • By Shadowace
      I have a 2016 artic cat 700 tbx seems like the power steering is not working what some obvious things that I can check.tks.in advance.
