2006 Polaris Outlaw 500, what goes on fenders?
Trentg
  • Admin changed the title to 2006 Polaris Outlaw 500, what goes on fenders?
    • By McG75
    • By p5200
      I'm assuming, it's alright to test the engine after adjusting valves without the rear axle installed? Can someone please verify this? I'm waiting on axle parts and wanting to get that done while waiting. Thanks! 🙂
    • By dvs1961
    • By rockfresh15
      Hey all, I'm a 2-stroke quad/dirt bike guy, new to utility atvs. Just picked up a pretty clean looking 2005 Kodiak 450 4x4 with about 1,000 hours on it for my dad.
      The first thing I noticed when we got home was oil leaking from a seal on the rear axle. Pictured below. I've been staring at this frigan Partzilla diagram for days and can't figure out what part this is. What is it and what likely needs replacing/fixing?
      Also wouldn't mind any recommendations on the next things to check. The owner said nothing's been replaced on it but oil since it's been in service. Def needs new rear tires.
      Thanks all!
