Linhai Bighorn What Oil to Use
By quadnut20
By sunn
The clutch engagement on my 2021 cforce 400s was approx 2700 RPM, very abrupt/not smooth. I obtained a "kit" from RNG consisting of a blue painted spring (spring force unknown) with 12 gram weights, as measured on my postal scale. Installation was easy; 18 mm and 30 mm (not 32 mm as seen on other writings) impact sockets for clutch housing removal. The resultant clutch engagement was still up to approx 2500 and very abupt/not smooth.
The RNG spring was slightly longer than the stock spring, but felt slightly easier at initial downward force but had more resistance than stock as I continued to push down. RNG would not tell me what the spring force was.
I am really struggling to get any answers on the best combination of spring / weights to achieve a smooth engagement of maybe 1800 RPM. Note; idle RPM is approx. 1600.
I have searched all the forums and cannot find good information, and RNG appears to be not willing to share information. What gives here? Anyone with experience to share?
By Coyote251
By Mudseeker149
Just bought the atv, sounds like there’s sand in a bearing near the clutch! Any ideas?
