  • Admin changed the title to 2005 Yamaha Kodiak 450 noise from clutch
It's likely that the one way bearing that's part of the centrifugal clutch has failed. To check it out the cvt clutches have to be removed first.
There is a cover in behind them that gets removed to access the cf clutch system (that runs in engine oil btw).
What i would do is either pull the cover and pull the belt off of it and run it just to make sure that the noise is actually coming from the clutch itself. If the noise is still there id pull the clutch and check out the rollers in it.
And no sir theres not a special tool thats needed to remove that clutch its just a 22mm socket and then it pulls right off.
  • 3 years later...
2001 Yamaha Kodiak. Rebuilt carb after sitting for 10 years. Got her runnin but now this clunking noise is happening and sometimes the engine stalls hard like the tranny or clutch abruptly stops the engine. This was not happening 10 years ago. Also the clunk will happen and the rpm's spike. See video. Any ideas before I tear into it?
Can't say for sure but it's possibly from the one way bearing that's connected to the engagement clutch that works with the drive clutch.
You'd need to pull the drive (primary) clutch first - the one mounted on the crank that turns the belt. In behind is the clutch/bearing that runs in oil which does the engagement. They are known to wear out eventually.
    • By mehim
    • By logray
      Hi all,
    • By Ant-Knee
      I am trying to rebuild an engine for a '97 Kawasaki Prairie that I recently picked up. There is one head bold that just won't let go. Nothing I do seems to make a difference. I have been putting penetrating lube on it for two days straight and I am afraid it is going to break on me. What is your best advice for getting the sucker out? I have tried a rechargeable impact, a pneumatic impact and penetrating lube.
    • By quadnut20
      Just picked up a 2025 Yamaha Kodiak 700 fixing to do a EPI Clutch mod to it since I dropped bigger tires on it !! Air box , exhaust , and programmer next !
    • By sunn
      The clutch engagement on my 2021 cforce 400s was approx 2700 RPM, very abrupt/not smooth.   I obtained a "kit" from RNG consisting of a blue painted spring (spring force unknown) with 12 gram weights, as measured on my postal scale.  Installation was easy; 18 mm and 30 mm (not 32 mm as seen on other writings) impact sockets for clutch housing removal.  The resultant clutch engagement was still up to approx 2500 and very abupt/not smooth.
       The original spring was labeled p/n 0951-1021 (specs for spring force 300/1600) with 18 gram weights.
      I called RNG who told me the kit should work fine for my ATV, but that wasn't the case as I found.
      The RNG spring was slightly longer than the stock spring, but felt slightly easier at initial downward force but had more resistance than stock as I continued to push down.  RNG would not tell me what the spring force was.
      I then tested the clutch with the RNG spring and the OEM 18 gram weights with the resultant engagement RPM of about 2050 RPM, a little smoother engagement but still not good.
      I am really struggling to get any answers on the best combination of spring / weights to achieve a smooth engagement of maybe 1800 RPM.  Note; idle RPM is approx. 1600.
      I have searched all the forums and cannot find good information, and RNG appears to be not willing to share information.  What gives here?  Anyone with experience to share?
