I also just ran across the Chinese-made ATV's, was shocked that you can buy a 250 new for ~ $2,000.  Hoping to see folks who have knowledge chime in here with their experiences, whether positive or negative.  The 3 YT videos I've watched so far seemed to show a machine that is a decent value for the $$$ but have not yet seen one with any evaluation after several hundred miles of use.
Most of the Chinese clones from TSC, Lowes, etc, are OK for what they are.  Reliability seems to be ok for a few years, value is pretty high.  They're not going to run 20+ years trouble free like a Japanese one and repair parts and support are hard to come by.  Like anything imported; decent value for the money in the short term, depreciating quickly over time.
TY for that evaluation, Mark-
Any idea about how one of those 250 Tao Tao [or whatever they are] might do for snowplowing if chained up?  Our snow is usually pretty dry and fluffy and I try to get on it before it has a chance to thaw/refreeze.  My usual plowing chore takes about 45 mins with that Bayou 300 [no chains] for a 6-10" dump on a 200' drive plus about 2000 sq ft parking.
For $2000 and change I could buy one of those TaoTao's, plow with it this year while I tinker with the Bayou and then sell it once I'm up and running again...
Edited by OldDawg
Fat fingers...
Tao Tao and about a dozen other Chinese brands are really just 80's Honda technology.  They copied the patents on stuff as soon as the patent expired.  Parts aren't usually interchangeable, but you can see where they just copied an old Honda motor.  The are ok, not extremely reliable, but you'd probably get a winter out of it (I say probably because I've seen them crap out in a couple hours and I've seen them last years).  The only real probably with them is support.  Hard to find parts, hard to find wiring and drivetrain diagrams, etc.  Oh, and resale value is complete garbage, one of those a year old here in the south is worth under a grand.
Once again, TYVM for the feedback, Mark.  I may just decide to roll the dice on one regardless.  If it lives thru the winter I'll have it for an extra for friends/family to ride and it will only have cost me a grand to plow all winter, which is probably about half of what it would cost to have it done and I won't be last on the list due to being on the end of the road....already plowed 6 times this winter [borrowing neighbor's but can't impose all winter] and am expecting a minimum of another 20 times.
I've been interested in these as well.  Reading the manual, it is claimed that they should only climb 15 degree hills.  That is nothing.  I bet they will do much better.  What experience have others had.  To me, this warning sounds like lawyer talk to limit there liability if rolled.  Will thes machines spin all wheels on dry grass?
thanks, tom
  • 4 months later...
thanks, tom
Yes they will.  The backside of the dam for our little pond is about 30 degrees, and from a standing start in low range, Axis 500 will zip right up it.  If muddy it will require a running start, but that is more a function of tires than drive train.
tom
    • By prdicon
      Polaris it a bit cheaper.
      Let's say 3-5 years from now.
    • By geezer99
      Well, I bought the Axis 500 sold at Lowes for $8999 a couple days ago.  This post will be about my impressions as I use, fix, and abuse the machine.  I will add to the post as I gain experience with it.
      Thanks to other posters on this site warning of new machines with loose hardware, one of my first actions was to crawl all over it checking fluids and connections.  Zirks were all freshly greased, fluids in engine, and gear boxes were up to level.  One of the little gas struts that help lift the bed to dump was dangling with only one end connected, and the other strut had not been fully tightened.
      The rear gearbox does not have a differential in it.  It is essentially a solid axle.  Tight turns on lawn will leave tracks, and turns are not as tight on pavement.  In my case this won't matter much, but if you plan to use it on a lawn, this will create tracks on turns.
      To check engine oil you need to remove both front seats and a plastic cover.  This according to the manual.  I'm pretty sure it can be checked with that stuff in place, either from under or above, but that remains to be seen.
      I am not used to a CVT transmission.  I am used to a clutch and multiple gears.  This one requires giving it plenty of gas out of the hole and then backing off to get it to shift up.  I'm sure I will get used to it, but I'd like to be able to take off quietly if I want to.
      The doors have bungie cords to act as springs to close them.  I removed the driver door so I would not need to fight the constant pressure to close.  Problem solved.  I will leave the passenger door as is.  Gotta keep the grandkids safe.
      Here is some stuff I like:
      I was concerned about there being enough torque to slowly climb a steep hill.  There is.  I will elaborate more on this when I've had it on my steeper trails.
      The display has dedicated lights to indicate status of gear position, low oil pressure, over temp, and a bunch of other stuff.  This helps a beginner with feedback that an action taken was successful.
      The sparsity of knobs on the tires dig in well on most surfaces.  I bet they wear out fast on pavement.
      The tilt bed has a tail gate that is easy to operate.  Much like early Japan pickups.
      Steering is responsive and little slack.  Remains to be seen how long to get loose since the u-joints are operating at quite sharp angles.
      Seats are pretty nice.  Will be interesting to see how long it will take me to poke a screw driver though them.
      Seat belts are included to hold grand kids in.  Won't go over 5 mph if both aren't buckled.  Yeah, it works to buckle them empty.  Doing this leaves the belt high on back, so you don't have to sit on it.
      Hauling it home, my trailer wheel wells were too close together to clear the tires of the UTV.  This required driving it off center a bit, with one set of tires inside the wells and one side driving over the wheel well.  Creeping over the one well required climbing a 10 inch vertical well.  The ability to lock the front axle differential kept both front wheels pulling as I drove the one side up and over the wheel well.  The guys at Lowes were impressed.  They won't touch any but an unobstructed flat trailer loading.
      tom
    • By kingkw
      I have a Harbor Freight tire changer. I could not get the tires off the rim.
    • By ButchM
    • By dink1970
      Explore your Can Am Parts and Accessories from UTV Wolfpack. We have a great selection of products for the Maverick XRS 64 and  Maverick XRS 72 Accessories.
      https://utvwolfpack.com/shop/can-am/
