I have a 1990 Honda FourTrax 350. I am trying to work on the rear brakes and I cannot get the hub off I have pulled the cotter pin and the nut off the axle The hub will not come off is there a certain trick to this. I have tried to use a sledgehammer hitting the tire and trying to get it off but it is not coming off.
The hub must be seized on the axle splines I'd think. Give it a squirt with crc, tap it a bit on the flange out near the studs to try and get it to rock just enough to let the crc creep down the splines, then try tapping it, or using a puller.
    • By Cj Winds
    • By TomJulio
