  • Ajmboy changed the title to 1998 Yamaha Big Bear 350 Neutral (green) Light Stays On
36 minutes ago, Ajmboy said:
So it stays on even when in gear? Does happen in all gears where it stays on? If so, sounds like a bad switch. Try unplugging it. To eliminate the possibility of a bad switch, I would probably just replace it as its cheap enough. You can get these on Amazon like:
1998 Yamaha Big Bear 350 Neutral Safety Switch
Is it ok to leave it unplugged and still use the bike?
Does the light go off when you unplug it? The point of that is to not start it in gear, as it can be safety issue if you do start it in gear. I don't think it has an effect on drivability but because its a safety/neutral switch, I can't in good sense tell you its ok to leave it unplugged and use the atv. As an owner, its up to you what you do.
Thank you for your help
    • By Thumpinhard25
    • By fwsamm
