2009 Ranger 700 XP steering column
By flyinbrian365
What's Covered:
By sunn
Anyone with experience on relocating the miniscule battery from the front lower center wheel area to the left rear wheel area on the Polaris Sportsman 570?
By erkme73
Just purchased the subject 150. It makes a crunchy chunky sound when reversing. There was a lot of slack on the chain so I assume that was it, but when I took the chain off I noticed that the transmission output shaft has a lot of slop in it. I have to assume that's not normal. Can anyone confirm?
By hporter1208
Okay, so I have a 2002 Rubicon 500…bought it last year and it sat for several months until I put a new rear axle in, FINALLY got that done and was super excited to finally have my wheeler going, just to notice a strong gas odor. Popped the seat off and sure enough, pouring gas from the carb overflow. Fast forward a few more weeks and get the new carb and get it in, no leak! Yay. Except now I have no spark. 😒 I’ve tried another plug and checked and am getting no power to the coil pack. I’ve read and read and mostly what I’ve found is ECU, which is fine…but I like to exhaust all avenues before buying the more expensive parts just because I don’t wanna spend the money and it have ended up being something simple that I overlooked because I was trying to rush. 😂 I don’t know if it’s relevant, but I read on another post that someone had similar issues with theirs and it was the sensor on the side of the carb, just a thought since this literally happened after I put the new carb on. It also displays “- -“ on the display screen where it should show the gear position.
By Tuzz
Bucking started about a month ago and works ok after 1/2 hour warmup. Today while working on it i discovered that if i put the ignition switch in LIGHT position it runs fine right from the start.
I'm stumped! Any idea why this could be?
