2004 Arctic Cat 400 TRV Won't Start
By tepin
By Shorty51
By spigmef
I bought a 2008 arctic at 366 with 120hrs. When i red line it in neutral is smokes blue a lot. When I put it in high range it has problems getting over 35km/h. I bought it and had to clean the carb. It ran ok after i cleaned it. Not I have this problem.
By Asand211
