So not sure how there was no oil in the case but currently into an engine rebuild due to running it dry.  Luckily the damage was a lot less than it could have been.  The worst of it is the connect rod as it got hot.  The piston was seized onto the piston pin.  Trying to get it loosened up to get some new parts in here.  Would anyone reuse this connecting rod?
So doing lots of research, looks like they only sell the connecting rod/crankshaft assembly as one piece.  Does anyone know if the connecting rod comes off of this assembly?
If the rod's blued at the top I'd be very reluctant to reuse it. That said, they are often a little blue from the manufacture.
If it's been overheated though then I'd biff in. After that no oil situation the crank needs stripping for cleaning.. in which case new pin, bearing, rod are all pretty much mandatory.
All those parts I mention will be available I'm sure.
    • By digrig
      Hey everyone,
    • By Joeguy
      Did a top end rebuild, honed .010 over, new piston, rings, valve seals, etc. When i re assembled i only had like 30 psi of compression but then after it sat all night i now it seems to have gained some somehow, there is much more resistance pulling it over and i even got it to fire for a few pops. Issue i got is that it makes a loud squeak noise through the intake i believe (goes away when throttled so something with carb area) and it seems to not want to run well. I took head cover back off and timing seems fine so im not sure if something is sticky and that's why i got some change over time or maybe the valve lash is messed up after doing all this, i did get another cam for it but i wouldnt think it would make enough difference to need to re lash. Any insight on next step would be appreciated, i will be looking up how to do lash on these because it is a very weird angle to slip a feeler gauge in.
      Actually cam is slightly off now that i look at the picture, thought it was good while looking in person. Hmm.
    • By Atomusthenes
    • By Ironworker709
      I have Grizzly 700 that has been pretty much totaled out in a bad accident, but it will still run and drive good...
      Will this engine swap into any of the Yamaha UTV's like thr rhino and Viking 700's?
      Was just going to sell it as is for a engine for someone who needs one pretty cheap..but been thinking about getting a UTV for the family and maybe find one with a blown engine cheap and swap it out
      I already an excellent shape 2001 Big Bear 400 4x4 for us..but kinda been looking for a good used UTV for us and the grandkids on our property to play with
      Not sure of the year..i can't remember what year it was when i picked it up for a buddy a few years ago..he went to jail after he totaled this thing and told me to pick up a few things at his house he was renting and just keep them for myself since he owed me a bunch of money before the landlord sent them to the dump...
      The first picture is when i went and picked it up for him..second is how it is now..frame is all twisted up and plastics are fubarred..going to sell the rims and tires.they stick out way too wide on my Big Bear
