    • By shorty
      I removed a winch, mount brackets, relay box from my kawhockey ATV.. also a sturdy steel tube holder for a gas can.. CHEAP to someone who wants them
      I went to NYC over the weekend to see the tree at Rockefeller with tha family, and on the way down from about 50 miles north could not help but keep looking in the sky while driving at diffent lights. Planes, small planes, choppers? Some of them looked like slow moving drones but not really sure. If you are in the tri-state area, you can't help but wonder what's going on... thoughts?
    • By Eric C
      I have looked at every thread I feel like, but with no resolution. Its always the same with a no spark issue:
      Replaced CDI,
      Replaced Pickup Coil (Pulsar)
      Good continuity from CDI to green white wire at ignition coil.
      No Pulse at ignition coil on the green white wire. (testing with test light on Pos of battery.)
      Good 12+ V on the hot side of ignition coil.
      I swapped the wires around on the Pulsar.
      The grounds seem to be good for the blk/y wires throughout bike.
      Brand new battery.
      Brand new stator and Pulsar
      Tried 2 new CDIs
      Brand new rectifier
      I get about 300 Micro A/C volts across the two wires on Pulsar when cranking.
      I am currently cleaning the connections on the rectifier because they were burnt. I am not even sure if it makes a difference because I am told that doesn't produce spark anyway and is only for charging system.
      The fly wheel looks OK, is the pulsar supposed to be connected in the direction with the metal "Button" facing towards the flywheel?
      My bike is a 1995 bayou 300, but I seem to come across same issues on web but no resolution on these things.
    • By Krazo
      as title states, what are these wires?   I took off the rear plastic, and right behind the brake light, these wires are all disconnected.  Not sure what they go to.  Aside from my current issue of what appears to be a bad coil (replacement ordered) the atv has run fine for me.  I just bought it this past winter and spent time replacing front end components but motor has run fine until the this past weekend.  By the looks of these wires they've been unplugged a while.  only thing I can think of is they're for trailer lights maybe....?  but i really don't know.
    • By cfauvel
      there are two part numbers that come up for the voltage regulator
      32800-44D21 model Y
      32800-44D31 model K1
      I don't know which one to get .
      how do I know what model the ATV is?
