Prairie 360 Diagram Doesn't Match What I Have - Help?
By Arizona
Just recently bought a dead 06 Eiger, Can someone post or send me a wiring diagram for it:?
Need to check all wires, no power in most places, Cant seem to read the ones from online manual,
too blury and cant tell wire color. Just too small. Thanks Az
By TomJulio
I recently noticed my Fourtrax 2WD has 4WD wheels installed on the front. The back spacing is significantly different than 2WD wheels and they are almost touching the strut springs and the tires actually do touch the springs.. So far, no luck locating 2WD wheels to correct this issue.
By Olchap
Hi, I am new to this forum I am currently working on my 1989 Yamaha front end. The cv axles were bad so I changed them on both sides with all new wheel bearings. Now I'm looking at the front brakes and the 2 cylinders for the brake shoes on both sides do not work at all. I am also new at working on brakes so its a mystery to me what needs to be done to fix the cylinders. Can somebody please help me with these brake issues? See the image below.
Thank you,
Olchap
