waterproof your engine????
By picriver
new ignition switch
four wires - green, red black, black with white line
atv four wires - pink, pink with white line, black, red
which is attached to which, please and thank you?
By David Cameron
The small waterline insert for the hose that goes from the water pump cover to the thermostat housing has corroded off. I only need the insert on top and behind the thermostat housing that the hose goes over and can't find just the insert. It looks like it may be pressed in. I've have been told the entire motor housing needs to be replaced. The pic with the red line indicates where the hose and insert would be and the insert looks like the pic of the water pump Any ideas would be really appreciated.
By RRP
Does Anyone know the Fuse is for these two Accessories wires in the Light Pods (color: red and orange wires) ?
Checked all the fuses with a tester, and they were all fine.
By p5200
The cable was missing when I bought this atv. I'm not sure exactly, what all is missing to use the reverse. There is a small lever that has a notch for a cable and a red button on the left handlebar. Also, there is a linkage on the right side engine cover which has a cable slot also. I'm hoping, when I put that cover back on, the cable lever was in the correct position. Any info on what all is required to get the reverse going on this would be greatly appreciated!
