Attn: Yamahabansheeboy!!!
Similar Topics
By gatorschevy
I own a few older quads mix of kinds a couple of Yamahas, a Honda, can-am a Kawasaki, they are older quads but in good shape the question of the day is....... what's the best way to polish up the plastic?
By Oger69420
Just like the title says how do I find out what I have here I was told that it is a 1985 200 That is all I know and I need to Start looking for parts
By rebeltaz
I've got an 03 Prairie 360 4x4 that needs a left front ball joint and knuckle assembly. On the diagram (from PartShark - https://www.partshark.com/oemparts/a/kaw/50a852a0f870021a9c423c20/suspension ) they show the ball joint as a part of the knuckle assembly, extending down into the lower a-arm and held on with a nut. On the four wheeler I have, the ball joint is pressed into the lower a-arm and extends upwards into the knuckle assembly and is held in place with a bolt going horizontally, clamping the ball joint in place.
Any idea on why the diagram is different and how I can find the actual parts I need?
By slow_po
I have been sorting out some of the problems on a new to us 500 x2 and it seems I may have a sending unit problem. I bought a new gauge cluster and once that was hooked up, I see the fuel level bar graph flashes constantly.
Watched a yt video about a similar problem and it looks like a cleaning is in order to get the fuel level working again. My question is - would replacing fuel pump, regulator, etc. be wise since I will be in there anyway? The machine runs fine and doesn't seem to have fuel delivery problems (yet - understand it only has an hour or two of use by us while I work on it).
Similar Tagged Content
- 6 replies
- 3,170 views
- 0 replies
- 1,596 views
- 14 replies
- 3,381 views
Gallery Images
