Kawasaki prairie rear differential nut
Similar Topics
By Hoyt1500
I'm rebuilding a 2004 Suzuki LT80 and am wondering where everyone is buying parts for their carbs, clutch, and transmission. Has anyone had success with Amazon parts or should I stick to OEM parts that can be found on partzilla or suzukipartshouse.com. I found one old thread where people talked about only buying OEM for top end but other locations should work.
By p5200
I seem to have no resistance at all on the rear brake pedal and no rear brakes. They were pretty good before I removed the right side crank cover. In order to get to the lower bolts of the cover, I took a piece of baling wire and wired the pedal in the down position. I assume, that caused at least, part of the brake problem. I can't see where fluid came out but, I did have to add more fluid. Added the fluid but still no resistance to pedal. Should I try to bleed the rear brakes? Thanks
By Wrye Pipeworks
Picked up a 2000 prairie 300 4x4. It is leaking out of the rear output seal where the driveshaft contacts to the engine. I'm havi g a really hard time finding out how to remove the driveshaft online, finding a service manual, and finding the seal on a parts diagram. Anyone know how to remove the driveshaft or know where a service manual is for it?
By p5200
By vwhobo
Does anyone have a used set of tires for a '97 Honda Recon pretty close to Sumter, SC? Not looking for anything new or expensive but they've gotta hold air and have some tread left. Wheels not needed. Sizes are 22x7x11 and 22x10x9. Thanks.
Gallery Images
By SYKOLINCOLN,
By onebad400ex,
By LT250R,
By LT250R,
By Shortcut,
By Guest,
By quadcrazy,
By oxidized_black,
