1998 Suzuki Quadrunner LT-F250 Gasoline in crankcase
Parham
I just bought this a couple of weeks ago.  The oil sightglass was FULL. When I opened the fill plug, oil/gasoline LITERALLY gushed out and flowed for several seconds...FROM THE FILL PLUG!  I drained it, changed the filter (no metal bits), and refilled with new oil.  Opened up the carb and cleaned the float needle.  Blew into the fuel inlet while manipulating the float and it seems to work.  Buttoned everything back up and it runs good.  Now my question...was the fuel getting into the engine because of a stuck float needle or is there something else wrong?
  • Solution
Sometimes gas can leak past a worn float needle and seat you should replace it. I usually turn my gas off when not running and its going to be sitting for a while. I got used to doing that with my lawn tractors, briggs are notorious for that.
You need to have a look at your fuel tap and see if it has a vacuum hose on the back of it. If it has a vacuum hose then that tap has no off position. In normal use you leave it on run or reserve and when the motor stops the lack of vacuum closes off the tap, when it fires up the vacuum opens the tap. The middle position of the tap is called prime and it's on all the time, it's for filling the carb if it's empty and there is no vacuum. If you don't know it's a vacuum operated tap and turn it to the middle position when you get off you are bound to get a flooded motor.
If the tap is playing up it can fail to close when the motor's stopped. It only needs a speck of rust under the vacuum operated needle and seat in the tap to make it stay open, then you've got three on positions and no off. They can also get a hole in the diaphragm that operates the tap. If the diaphragm has a hole fuel goes down the vacuum hose into the motor.
Lots of float needles leak a tiny amount, not enough to effect the running but enough to fill the sump with fuel when they sit for a while. The tap is the first and most important thing to get right. The manual taps can also develop leaks. There's a rubber washer in the manual tap with holes in it. On some models it's possible to flip the washer over so you are using the new unworn side. I'd make sure the tap was turning off completely before buying a new float needle..  It's easier just to pull the hose off and check there are no drips..
Edited by Mech
Mech...I knew you would try to help!  Thank you!  Here are some pics...I do not have the vacuum petcock.  Looks like someone might have replaced it already.  There is a short piece of hose on the carb that is plugged.  I assume (you know the acronym I bet...) that is where the petcock was connected.  There is also a piece of hose, disconnected, that disappears under the dashboard.  Probably the original petcock vacuum hose.  What are the positions on the petcock shown?
I don't know what those symbols on the carb mean..  Off will be horizontal though..
I don't recognise that carb from the hose layout, it's not the standard carb we get here, but I think that hose at the top center in the last photo would be a vacuum, either for the pump or the tap, and there is probably another vacuum port for the other, possibly that plugged one. It's usual to have a bigger hose going to the pump, and a smaller hose going to the tap. The two vacuum ports have fittings to suit.
In the first photo there's a hose opening upwards, that doesn't look  right.. if it's a breather it should be aiming down to keep crap out. And the fuel hose in that photo looks about ready to split where it goes on the carby.. If that was a standard suzuki carb that up facing hose would be a vacuum hose I think.
On the carbs around here, the left side of the carb has from front to back, a small vacuum hose fitting(pressed steel pipe) aiming up, then a larger vacuum hose fitting(machined brass) also aiming up, then the fuel at the rear(machined brass) also aiming up, and on the right rear there is a breather hose fitting facing down.
I'll have a look later and see if I have an old carb like that to check what the ports are..
Mech..I'm betting the positions on the petcock, based on the symbols, are up is "normal" (taller standpipe), down is "reserve" (shorter standpipe), and horizontal is "off". That "hose opening upwards" is not connected to the carb.  It disappears into the instrument panel and I can blow through it.  I think it's what was connected to the original petcock valve.
I'd doubt the hose goes to the instrument panel..  They have an engine and airbox venting hose that runs up under the range/rev/4wd panel where it branches and runs back down as two open breather hoses.. You might be blowing into one of them. I'd try and aim it downwards so it doesn't accumulate water or dirt.
I'd also change that fuel hose going onto the carb.. It looks like it's old or the wrong size and wall thickness.
I don't recognize the carb either the hose with a screw in it looks like s fuel hose the other look like vacuum hose and the symbols on the petcock are strange it looks like open and closed, but im sure you have already figured it out.
  • Similar Topics
    • By Params_sweden
      Hi! I'm new to the forums  I'm working on my klf300 that isn't starting anymore. I accidentally ripped apart the spark plug cap, and I'm curious to know the resistance of the original part, it's not mentioned in the manuals. If anyone with a KLF300 could measure their OEM or known working replacement spark plug cap I would be very happy  NGK for example has spark caps with resistances 0, 5, 10, 15 ohms so it seems to be something that I would like to match as close as possible with the original part.
      Thanks,
      Pär, Sweden
    • By PineAppleCawks
      Morning all, hope everyone is off to a good start with their day.
      about 2 months ago I bought a 95 bayou 300 for a hundred bucks. It was obvious the thing was gonna need some work and I'm up for the challenge. Just looking for some advice on how to get this thing going. The wheeler has an array of problems and I've done a good bit of reading around and learning about the machine lately, but I'm stuck at an impasse and not sure exactly what I need to do to proceed.
      So to start with the stuff that was obvious to me; The wheeler has definitely been flipped, the handlebars and steering column are bent, both front and rear racks were bent and have been cut in places to allow the previous owner to bend them back into a rough idea of what they once were. Along with this the little box on the handlebars with the key and lights was completely missing, The ignition wires were hanging out the side and twisted together and the light wires were just freely hanging down below and were also cut, as they have no bullet connectors on them anymore. to deal with the loss of the reverse lockout they strung a cable through a hole in the plastic and attached a random handle to it.
      As a preliminary I went ahead and purchased a info box complete with key and reverse lockout and a voltage regulator (as I had read they commonly go bad). I have a small question about the ignition wiring, but I will save this for later as this brings us to the actual problem. No matter how good I do at replacing parts such as this I will never know if any of it has worked because I cant get the transmission to shift at all, but most importantly I cant get it to shift into neutral. I did some research on the problem which consistently lead me to something having to do with the spur gear behind the secondary clutch. I pulled the clutch cover and inspected, Everything was in place with no loose bolts or anything. I went as far as to remove the spur gear and the levers and springs. I could not find any visual degradation that would lead me to believe this part is the issue. With time running thin in the day I went ahead and put everything back in according to the manual. for a brief moment I was very excited to find that the shift lever was actually giving me some sort of tactile feedback and felt as if it was shifting, but this was short lived and it all seemed to jam up and stop doing anything after a few seconds.
      When I had the clutch cover off I had my son actuate the shift lever both up and down while I was laying on the ground looking at the spur gear. It seems that every once in a while it was able to grab the spur gear and spin it, but this will ONLY happen if im shifting up. It gets completely jammed trying to go down. Occasionally I can get it to spin partially as I am shifting down, but in those situations it freezes and wont spin any further even if I try to coax it along with a screw driver. What this feels like on the shift lever is there is no feedback. All I feel is the resistance of the spring and then it hits the a spot where it just stops the lever from moving. I get a very distinctive metal on metal "tink" and that's it.
      Anyway this is my big hang up at the moment. If I cant get the wheeler in neutral I cant test to see if any of the electronics are working, let alone see if it will turn over for me. As a side note the pull starter is busted, when I pull it I just get the resistance of the spring and it doesn't seem to engage with the motor at all. When the clutch cover was off I grabbed the clutch and spun it clockwise which proved to me that the motor has compression and freely spins.
      So that's where I am at now, and I am more or less out of ideas as to what I need to do to either further diagnose the transmission or (fingers crossed) fix it. I figure all the other stuff can wait, as this seems to be the big hinge point on the project at this moment.
      I wont be at the farm till later, but when I am I will make a short video of the spur gear so you guys can see first hand what's going on.
      I want to thank you guys in advance for any and all advice you may be able to give me. I am glad to have a resource such as this forum and look forward to hearing from you guys!
    • By p5200
    • By noticon75
      I just got a 02 Quest 650 the closest Can-Am dealer is an hour away so I need to order an oil filter there is quite the price differences on Amazon for oil filters.  What is a good filter to use?  I am new to doing maintenance and you help is appreciated.
    • DIY like a pro! Shop from over 1,000,000 Repair Manuals at eManualOnline.com! As low as $14.99 per manual. Shop now.
    • By MaxxerManDan
      Hey guys. Newbie here. I have a '21 Maxxer 450 and took it out yesterday. The digital fuel gauge read "full" for the entire trip, despite how much gas was left in the tank. Does this sound like an easy fix? Any suggestions on a diagnosis? Thanks! -Dan
  • Gallery Images
