I am renovating a 1996 Polaris Sportsman 500. It has not run for several years and stood outside in the owner's yard. There was some gas left in it which I need to drain. Do I need to drain the tank, fuel pump, and carburetor? Is there one place to drain it all?
If you drain the tank and drain the carb with it's drain screw on the bottom, then fill the tank and switch the key on and off a few times with the carby drain screw still open, it will empty the pump too.
A think to watch for is condesated water in the tank. It might pay to take the tank's fuel tap out and rock the bike around to make sure you get everything out of it. Then a quarter cup of methylated spirits in the tank with the first fill will absorb any water, which will then get burnt up as it goes through the engine.
The transmission oil too, it might have condensation in it if it's sat outside. If it's been run, and the oil hasn't got a milky or cloudy look to it, it will be ok, but if it hasn't been run, the water might be in the bottom and get mixed into the oil once it gets used.  Oil is cheap.
Edited by Mech
Since you don't know what fuel was being used, and if it sat for very long with ethanol fuel in it, I would pull the bowl and make sure the gas hasn't turned to jelly and rusted in the carb, I had a lot of trouble with that before I switched to non-ethanol fuel.
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By flyinbrian365
      What's Covered:
    • By kevinohio
      Topics covered include:
      AWD and differential repair
      Brake system service
      Popular related searches:
      Sportsman 570 wiring diagram
